What do reed spacers do???
Old Mar 7, 2006 | 04:43 PM
lt2strokerider's Avatar
Default What do reed spacers do???
what do thay do?and where can i get them for my 1992 lt250r?
Old Mar 7, 2006 | 09:30 PM
fastestkidaround's Avatar
They move the carb farther away from the motor thus giving you a little more on top and bottom and a good amount more mid. But with your mods I dont know if you'll fell them very much, maybe in mid and low end. I love mine they helped a lot with my almost stock blaster. I got them on planet blaster for 16 shipped.
Old Mar 8, 2006 | 04:42 PM
do you knoww where i can get them for mine?
Old Mar 8, 2006 | 08:24 PM
s9195's Avatar
I found that a reed spacer worked on my son's '03 blaster when it was a 220. It gave the quad alot more bottom end. He was able to keep up with the 240's on the holeshot and coming out of turns but they'd pull him on the straights.
But when we put the 240 kit in it we found that the spacer actually took away from mid range. This was after we had a great port/polish job done to it from CT Racing. We even tried the CT pipe and found that the Toomey B1 gave us a bit more top end. (CT doesn't know that we're not running their pipe). The only difference in the two was the header on the Toomey was larger towards the top bend.
lt2stokerider - not sure where you could get one. You may want to size the manifold and find something that is close like the Blaster ones.
Old Mar 8, 2006 | 09:11 PM
Try ebay.
Old Mar 9, 2006 | 04:27 PM
do you have to rejet when putting one on
Old Mar 9, 2006 | 08:42 PM
I did not have to rejet. You might though but I doubt it.
Old Mar 10, 2006 | 04:26 PM
s9195's Avatar
I didn't have to reject my blaster either when I put on or took off the spacer. I've been keeping a look out for a LTR250 spacer but havn't found one on ebay yet. My suggestion would be to get ahold of some gaskets for your inlet, then take them to your local shop and ask them what is in production now that uses the same size gastets (bolt holes and all). Who knows, Suzuiki/kawi/honda/yamaha probably still uses that same size for another quad/bike. You can also try using the diameter of your reed cage... just throwing out something that hopefully would help you....
Old Mar 10, 2006 | 04:30 PM
well thanks for your help,i found one on nacs racing.com..
Old Mar 11, 2006 | 12:39 PM
mahnster's Avatar
I think Rocky Mountain has them.
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
Bergmann
Aug 13, 2015 03:51 PM
