z400 clutch plate specs needed
Old Apr 30, 2006 | 02:58 PM
maczzz's Avatar
Default z400 clutch plate specs needed
I'm replacing my clutch on my 03 z400. I just opened the new TUSK brand clutches and measured the stack up on the old and new sets. The new tusk brand measures .028 in. smaller than the worn stock unit. Its all in the spacer plates, they are .004 in. smaller than the stock plates each. The fibers are the same size old and new. This seems just a little backwards, I know there is a lower limit on the clutch stack up height, but I don't have a Suzuki manual.
If anyone has this info, i'd appreciate it. I don't want to put it back together just to have to pull it right back apart because it slips.
Old May 12, 2006 | 11:45 AM
Semms40oz's Avatar
Drive Plate Thickness: Service limit 2.62mm
Steel plates: No service limit on thickness, just on distortion and its .10mm
Rocketx
Nov 16, 2020 07:25 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
txkevin
Sep 21, 2015 02:02 PM
lilgirlblue
Nov 23, 2000 03:23 AM
