Eiger Dead on trail
Old Jun 12, 2006 | 11:10 PM
BruteForceNewYork's Avatar
Default Eiger Dead on trail
Well yesterday we went out riding. My wife rode the eiger and two miles in the trail the eiger back fired. Now it wont start. the starter isnt working or even trying to spin. any suggestion?
Old Jun 12, 2006 | 11:28 PM
BigDimo2624's Avatar
is your battery dead?
Old Jun 13, 2006 | 01:04 AM
No battery is fine
Old Jun 13, 2006 | 01:33 AM
DDDonkey's Avatar
Check the ignition fuse, if everything works but the starter that is prob. the problem
Old Jun 13, 2006 | 08:23 PM
jeep6255's Avatar
will i pull start?
Old Jun 13, 2006 | 09:14 PM
When i try to pull start, the first pull is impossible, let back in and then you can get a full pull out of it but not enough to make it turn over.
Old Jun 13, 2006 | 11:08 PM
when you hit the electric start, can you hear the starter at all? or is it not getting any juice whatsoever
Old Jun 14, 2006 | 06:38 AM
quadduck's Avatar
Check the compression release on the motor, maybe its stuck or maybe that back fire bent a valve. My eiger pulls over with ease even before the motor broke in.
Old Jun 14, 2006 | 10:06 AM
rolsmojave3's Avatar
you were probley on the compression stroke when you tried to pull it....that makes it very hard
Old Jun 14, 2006 | 12:50 PM
zex129's Avatar
Dont want to sound negative, but if it backfired then the starter wont turn it over and the rope is hard to pull then Quadduck may not be far off, it may have jumped time /backfired / and bent a valve. May not have bent vavle but if it jumped time bad enough without bending valve then timing is off and causing too much compression to fight against with starter or rope. I Hope it didnt bend a valve. Good luck
