ran into a problem with my vinson 500
Old Jun 23, 2006 | 08:13 PM
bigred3's Avatar
Default ran into a problem with my vinson 500
I have a '04 Vinson 500. Last week i was riding on the power lines and had to pull my buddy out of a hole. Nothing seemed to happen at first but i was driving down a trail shortly after and it seemed as if my rear end locked up. It made a deep grinding noise. I could smell some gear oil but nothing was spitting out. I think its either one of 3 things. The gears, my rear end or my transmission. Has anyone ran into this problem or have any thoughts on what it could be.
Old Jun 23, 2006 | 10:44 PM
calsatman's Avatar
were you in 4wd when this happened? ive read a few posts where people were having problems with the front diff locking up and breaking the casing. seems the problem is the ring gear bolts come lose and lock the diff up causing it to break the housing.
Old Jun 24, 2006 | 01:02 AM
dranem's Avatar
When it locks up, does it happen when its in 4 wheel drive or can it lock up in two wheel drive.
I'd sure hate for it to lock up while flying down a dirt road.
Old Jun 24, 2006 | 11:43 AM
camozuki's Avatar
Mine busted and it was in 2wd. Have 600 miles on new diff. and all is o.k. May have been a bad batch of front differentials put together on Friday afternoon by a rockhead!!!!
Old Jun 24, 2006 | 03:19 PM
bigred3's Avatar
I was in 4 low when it happened, pulling in reverse. But when it started locking up on me i was in 2wd riding about 20mph down a trail.
Old Jun 28, 2006 | 07:50 AM
2c3's Avatar
2c3
pull your front skid plate off and you'll most likely see a hole in the bottom of your front gear case. if you smell the grease its leaking from somewhere. i smelled grease on mine and went to looking for it and thats where mine was. i had a hole about the size of a pencil in the bottom of my gear case. i took it to the dealer and he says a bolt had fell out of the ring gear causing it to bust the gear case. its still at the dealer. they've had it 3 weeks now. oh how i miss my ride.
Old Jun 30, 2006 | 09:30 PM
mudslinginvinson's Avatar
i ahve had my vinson for 2 years and i haven't had that happen to me and i am one heavy mudder.
03 vinson 5spd 4x4 26" swampwitches front/ 26" mudhogs back. (big pimpin ride)
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
