carb cleaning question
Old Aug 1, 2006 | 10:42 PM
robcont's Avatar
Default carb cleaning question
should i be dissasembling my entire carb to clean it (1st gear stalling) or is that gasoline additive enough? or the carb cleaner spray into the throttle?
Old Aug 2, 2006 | 11:09 PM
mucky's Avatar
to clean it right you should dissasemble it completely. and use a good carb cleaner
you can try additives but I dont think it will help you in what you need
Old Aug 2, 2006 | 11:39 PM
robcont's Avatar
another problem
i went ahead to remove everything and im trying to remove the float chamber but i guess the previous owner never did anything to this bike and im discovering everything now.
the screws stripped for the float chamber.
am i sh*t out of luck? do i have to buy a new carb? [img]i/expressions/face-icon-small-sad.gif[/img]
i should of really inspected this bike before buying it. i was in a rush cause i was excited.
Old Aug 3, 2006 | 04:43 PM
hondabuster's Avatar
Its very common to find those screw heads stripped. Not many people know about the philips screwdrivers with the anti cam out ribs. If the correct screwdriver is used, the screws wont round out. For now, just use a vice grips, or a chisle, and unscrew them...then toss them and buy new screws, most of us buy the socket head cap screws, so you can use an allen wrench, instead of a screwdriver.
You definetly dont need to buy a new carb, if this is all thats wrong.
Make sure the mixture screw is adjusted right, and that the pilot jet comes out, and the center hole in that jet is clean.
Old gas can cause problems, and non stock motor can too. Is the air box and filter totally stock...how about the exhaust?
Old Aug 3, 2006 | 05:16 PM
robcont's Avatar
i was trying a vice grip
ill try again
i had same problem on the throttle cable on the carb..screws stripped .. it was easier there with a vice grip
thx
Old Aug 4, 2006 | 10:33 PM
Timberjack's Avatar
Have you got a dremel tool? If you can get hold of one with a disc cutting/grinding attachment, grind in a slot on the top of the screw, until you can use a blade screwdriver. I guess you could do it with a file and lots of time too.
Good luck.
Ken
Old Aug 8, 2006 | 03:47 PM
smoovlatino's Avatar
I'm letting my carb sit in the garage soaking in Carb cleaner... I have a question...
I have a 2005 LTZ 250 and it only run with the choke on. I figured it was varnish inside the carb since it sat for about a year...
I did a quick clean of the carb yesterday and still had the same problem. Today, I completely removed it and doused it in cleaner. How can I tell if the jets are cleaned completely? Could there be another problem I should be looking for?
The quad can be ridden all day with the choke on, but as soon as the choke is switched off, it does not idle (idle screw was adjusted with no success).
Old Aug 8, 2006 | 04:18 PM
The pilot jet is plugged.
It can be very difficult to unplug it because the center hole is so small. Sometimes using one strand of 20 gauge stranded wire will unblock it...if that doesnt work...get a new one, they are about 6 bucks.
If you hold the jet up to the light, and try to look thru it, like looking thru a straw, you should be able to see light coming thru the center hole if its clean. If you dont see light coming thru the hole, its still plugged.
If you drain the float bowl,( theres a screw on the bottom of the carb float bowl for this, )before letting the quad sit for more than a week, this jet wont plug. Its the constant evaporation and refilling of the float bowl, while sitting over time, that makes that jet close up. That center hole is about .012" diameter.
Ty Speece
Jul 2, 2015 04:59 PM
Shawn_z400
Jul 1, 2015 03:37 PM
Spokes
Jun 22, 2015 08:02 AM
DOAinNY
Jun 11, 2015 10:34 PM
Jun 10, 2015 12:45 AM
