91 LT 80 runs only w/restricting air intake
Old Oct 1, 2006 | 01:07 AM
redfordtt's Avatar
Default 91 LT 80 runs only w/restricting air intake
I rebuilt the carb after first having the problem. Still will only run when I choke off the intake, it runs great then. Seems like it is getting air from some where else. any ideas?
Old Oct 1, 2006 | 01:11 AM
aksafari's Avatar
yeah, that's normal.
Old Oct 1, 2006 | 01:35 AM
redfordtt's Avatar
not normal. it will not run unless I physically pinch off the tube coming from the airfilter
Old Oct 1, 2006 | 12:04 PM
LT80's Avatar
LT80 Expert
Carbs do go bad at times. [img]i/expressions/face-icon-small-sad.gif[/img]
Before you get another, please try cleaning again.
Make sure to remove both jets and clean the holes in the jets and the carb body.
Also remove the brass needle seat and clean.
If that don't do it, I think it's (carb) has internal problems.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Frisky2050
Apr 9, 2020 11:19 AM
winn
Polaris Side by Sides
Oct 5, 2015 03:13 PM
robj
Jun 15, 2015 08:45 PM
garyt1975
Jun 5, 2015 08:53 AM
