lt250R Swingarm Adj. Bolt
The one on the chain side broke off? Anyone know what i should do? There the ones that stick out the back, if you pick the bike up by the grab bar the would dig into you shin... I havent had time to go look at it but saw a picture of it. Its at the other end of town right now. Thanks for the help Jordan
If it's broken inside the carrier you will need to drill a small pilot hole in the broken stud itself and buy a bolt extractor kit to get it out of there.You can still buy the new studs from suzuki at about $2.50 each.Or worse case if the threads are stripped bad you can enlarge the holes after extracting the broken 1 to a larger size stud.Good luck ..
Quadzilla Heritage
09-25-2015 01:39 PM
