LT185 has reversed compression
Old Jan 1, 2007 | 11:04 PM
henry1219's Avatar
Default LT185 has reversed compression
I have a 198? suzuki lt185. I recently took off the valve inspection caps off of the cylinder head. After doing this i put the caps back on and it did not start. It seems that it is pumping air out of the cylinder instead of sucking it in through the intake valve. I have worked on it every chance i can and cannot find a solution. I need to know what i did wrong and how to fix it.
Old Jan 2, 2007 | 09:45 AM
LT80's Avatar
LT80 Expert
I doubt inspecting it did anything. Did you touch/adjust anything?
Blowing by the valves would be over adjusted valves(too tight) or the valve is not seating.
lonerider856
Oct 13, 2023 03:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
