Kenda Bearclaw for Ozark?
Old 02-07-2007 | 11:52 AM
MountaineerTom's Avatar
Default Kenda Bearclaw for Ozark?
Mine are the 22x12x9 and they do fit on the stock rims, and there is no rubbing anywhere. They are actually mounted on a set of Honda rims that are the same size as the original Ozark rims. I still have my factory tires on the rims that came on the Ozark.
Old 02-07-2007 | 02:28 PM
CathastrophiX's Avatar
MountaineerTom: I see your Ozark doesnt have the fender extensions. In Sweden they have extensions on all fenders to make them wider:
AdrianXXX: Go with the bigger tires 25" tires, they improve ground clearance and looks better.
Old 02-07-2007 | 02:43 PM
Those are different. I had heard of them, but never seen a picture. I started to go with the 25 inch tire, but was afraid it would bog it down too much.
Old 02-07-2007 | 06:18 PM
AdrianXXX's Avatar
CathastrophiX: You are right with the ground clearance. I only consider whether this small 250cc engine would not loose power with these huge giants :-) Could you share some photos?
  #15
Old 02-08-2007 | 12:18 PM
Unfortunaley i have the original rear tires on now because otherwise i cant mount the snow chains, theres not enough room with the 25" tires. I dont think theres much difference in power with the kenda tires on.
Hondapolaris8596
07-28-2016 03:17 PM
clscott84
09-21-2015 10:16 AM
that1redhead
09-08-2015 11:47 AM
baysport
07-23-2015 11:37 AM
traumajunkie
07-05-2015 03:03 PM
Quick Reply: Kenda Bearclaw for Ozark?
