Suzuki Lt-230E Quadrunner wont turn over
Old Feb 27, 2007 | 09:42 AM
FoxDude74's Avatar
Default Suzuki Lt-230E Quadrunner wont turn over
I have a 1993 Lt-230 E that just wont turn over, it is an electric start and pull start, neither works, the pull start turns over fine telling me that its not the crank shaft, im either thinking it might need a new top end or its not getting enough fuel somewhere, the quad has good spark and good carb pressure so i know its not the carberator or the plugs, can anyone tell me what they think may be the problem or if there is some other problem other than the top end or fuel problem?
Old Feb 27, 2007 | 03:45 PM
shark66067's Avatar
It won't turn over or it won't start? If it just won't start check the compression, as you said it's getting spark and you may want take off the carb and clean it just in case and if that is good check the petcock to see if is pluged or a vent line is plugged. Only other thing i can think of is the timing got thrown off. Hope this helps [img]i/expressions/face-icon-small-smile.gif[/img]
Backwoods_badass
Aug 2, 2015 10:40 PM
Bulgin88
Jul 30, 2015 05:20 PM
ghost civic
Jul 19, 2015 10:13 AM
Jul 15, 2015 02:07 AM
bikedad3
Jul 2, 2015 02:15 AM
