Kingquad 700 battery issues
Old Apr 28, 2020 | 05:41 PM
  #101
Ejohn379's Avatar
Originally Posted by Kingding
Attachment 19309
Best battery for the money and it's found at the Autozone
Attachment 19310
Wires insulation carefully stripped back with a razor blade; be carefull! I made a slit then used my finger nail to pick off insulation.
Jumper wires were then wrapped around and soldered in place.
Note: I didn't cut the wires because if this didn't work I wanted to be able to tape them instead of splicing them back together that would leave a chance for future loose connections. I think solder without cutting is the way to go though much neater, tighter and waterproof with liquid tape.
Attachment 19311
Liquid tape applied
Attachment 19312
Everything hooked up and finished it took me about an hour.
I myself can now recommend the mod for all Kingquads that don't charge well.
Liquid tape from Walmart $4
Battery from Autozone $79
BattreryMinder $50
Not shelling out $300+ dollars to Suzuki' for their mistake. . . PRICELESS!
I like the Autozone battery because:
1) it's Gel
2) has room to stack multiple cables like I have for the winch, charger, jumper wires (Mod)
3) it's ready to go out of the box, no messy acid to worry about
4) it's made in the USA!
BatteryMinder is a better charger than the Batterytender from what I hear but it costs a little more.
Hey i have a question. I done the regulator mod on the black and white wire. I see u also done the red wire as well. Where did u connect the other end of the red wire to??
bzdok1234
30
Feb 23, 2016 01:55 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
