26" tires on Eiger = clutch issue for auto?
Old Mar 14, 2007 | 12:44 PM
Back40's Avatar
Default 26" tires on Eiger = clutch issue for auto?
Finally geting serious about installing some new tires on my Eiger. I noticed quite a few are running 26" tires on their Eigers How's the clutch handling the bigger tires? Any diff regarding clutch impact for auto vs manual?
Old Mar 14, 2007 | 07:33 PM
LimpingLizard's Avatar
You'll take off slower and lose a little steam going up hills unless you do a clutch kit. Put that in and it's nothing but grinning from ear to ear!
Old Mar 14, 2007 | 08:29 PM
jowils's Avatar
I hope there's not too much power loss!! I have 27" gators ordered for my '03 manual shift, and it will be a while before I can put in a clutch.
Old Mar 14, 2007 | 09:06 PM
I wouldn't think it's as noticeable w/ a manual.
Old Mar 15, 2007 | 07:45 AM
Back40's Avatar
LL, Is the kit needed due to the increased tire size or weight? I.E., if I stay with 25" tires but go with a heavier tire such as IT589 will I need a kit? Where did you buy your kit? Thanks for the feedback.
Old Mar 15, 2007 | 06:50 PM
I would think it's a combination of the size and weight. Probably less noticeable if you went with the 25", but it's only about $80 for the kit so I would do it even if I was running stock tires for the extra grunt.
I bought it direct from EPI (Erlandson Performance). There's a good post or two about building your own spring compression tool on here, though I used a neighbors press to do it.
Old Mar 15, 2007 | 10:04 PM
Towhook's Avatar
Anyone know were or what kind of jet kit I could get for my Eiger?
Old Mar 15, 2007 | 11:45 PM
DDDonkey's Avatar
I have the 26" gators on mine and I noticed a diffrence, when I did the tires I also put my pipe on and jeted it on the dyno. Like it has been said it is a little slower but not much, I didn't buy the eiger for speed either. If you haven't put a pipe on and jetted you might want to, just my opinion.
Old Mar 16, 2007 | 09:16 AM
Back40's Avatar
$80 is not too bad. The kit's I was finding were $190 and up. Thanks.
Old Apr 3, 2008 | 09:15 PM
buck1992's Avatar
my 06 5 spd has 26 mud lite xtr with type 7 rims all stock tires way a total of 99 lbs i weighed them the mud lites weigh 144 lbs lost accel and the ability to do a burn out in thick clay mud wich i will go away once i get jet kit and k and n filter.. so ive heard but that is my 2 cents
lightninboy
May 16, 2021 09:52 PM
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
traumajunkie
Jul 5, 2015 03:03 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
