lt230s
Old Mar 22, 2007 | 01:56 PM
usry's Avatar
Default lt230s
I own a lt230s, and i want to make it have more low end torque and hp, so what do i do?
Old Mar 22, 2007 | 07:02 PM
AtomicPunk's Avatar
Default lt230s
You're best resource for it is on this thread HERE
Lot's of 230 riders with all kinds of ideas!
Old Mar 23, 2007 | 12:11 AM
PoolGod230's Avatar
Default lt230s
Wow, MORE low end torque??? the lil units OWN the low end, and MID for that matter!! Atomic is right though, if you can't find it in the 230 qs help thread, it probably don't exist!!
Old Mar 23, 2007 | 03:31 AM
Frantic's Avatar
Default lt230s
the only ideas i have is to jet it and a aftermarket exhaust, i dont know if that will do alot, but it helped my blaster.
Old Mar 24, 2007 | 02:55 AM
JustRandy's Avatar
Default lt230s
Back the valve lash off a bit... maybe a 1/4 turn (maybe more, who knows). Do the intake more than the exhaust. It worked wonders for my 220 bayou... I moved the torque down in the rpm and actually added 2 more hp (according to simulation software). Not sure about the 230, but you can try.
Old Mar 24, 2007 | 08:15 PM
usry's Avatar
Default lt230s
I know but i want it to go 0 to 60 in nothing flat!
Old Mar 24, 2007 | 09:25 PM
JustRandy's Avatar
Default lt230s
Better get a bigger quad then! If you gear the 230 to do 60 then it won't get there very fast... And if you gear it so it has good acceleration, then it won't go 60.
Old Mar 25, 2007 | 10:39 PM
PoolGod230's Avatar
Default lt230s
usry, atomicpunk gave you the link, to ALL your questions so far.
add that link to your favorites, if it has to do with the 230 it is in there.
By the way, stock my 86 LT230S would do damn near 60mph! After a light bore, intake work, pipe, exaust, and up to 13 tooth on front 68.6mph and only slightly less wheelie happy than stock.
Now going for 273cc, and TOO MANY MODS TO LIST!!! Based on what I have learned from the link atomicpunk gave you. I am learning from their mistakes and successes. Check it out.
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
