87 LT230E CARB SPEC QUESTION
Old Mar 23, 2007 | 09:14 PM
NUTS4STEEL's Avatar
Default 87 LT230E CARB SPEC QUESTION
Hello, I just aquired an 87 lt230e, This machine fires right up but the problem I'm having is the engine rps's are eratic from a stall out condition to probaly 4-5k rpm and back down again. I removed the carb, disassembled, cleaned throughly and reassembled, no difference (except its starts better) I have'nt gotten a repair manual yet so could someone tell me what the correct setting's should be for the 2 jets on the lh side of the carb ?? Thanks very much for any reply's
Old Mar 25, 2007 | 09:15 AM
NUTS4STEEL's Avatar
nobody has a manual for this quad that they can look up the jet settings for me ? [img]i/expressions/face-icon-small-sad.gif[/img] someone please hook me up !!!
Old Mar 25, 2007 | 09:31 AM
270quadsportguy's Avatar
2- 2 1/4 on mixture screw from lightly seated and the other is idle which is up to how u like idle neither of mine have a good idle fuxuates a lil try rasing the needle on slide if it gets worse lower it a notch theres either 4 or 5 notches lower richens raise leans that would be where u need to check as this is your midrange of the carb
Old Mar 25, 2007 | 10:04 AM
NUTS4STEEL's Avatar
270quadsportguy: Perfect, Thank you very much .....
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
