Overbore and bigbore??
Old Mar 28, 2007 | 03:22 PM
CGriff's Avatar
Default Overbore and bigbore??
What is the difference between over bore and big bore?
Old Mar 28, 2007 | 05:46 PM
ZillaRider87's Avatar
bigbore is a term for making the cylinder larger around for more overall power. for instance a z400 turned into a 450.
overbore is lets say you blow up your top end, scratch up the inside of your cylinder, you bore it out very small amounts (.020, .040 ect) to fix the scratch, not for more power.
Old Mar 28, 2007 | 06:21 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Big bore is also the term used for the larger sized available engines. Nowadays all the 800's, 700's and 650's are considered big bores. A few years ago, a 400 was 'big bore'.
Jaybee
Old Mar 29, 2007 | 03:50 AM
CGriff's Avatar
So if I bore my cylinder .80 over is that a big bore or an over bore?
Old Mar 29, 2007 | 12:04 PM
bradr's Avatar
that would be considered big bore. over bore is in 3 decimals, like .080, .80 is almost 1 mm.
Old Apr 11, 2007 | 05:15 PM
Halfliter's Avatar
A big bore requires a welder. [img]i/expressions/face-icon-small-happy.gif[/img]
No, really, .080" over is just over 2 millimeters. That is considered a big bore to some. In fact I think the Raptors big bore is 2mm.
Old Apr 17, 2007 | 04:02 AM
UtahDuneRider's Avatar
any machine work done to a stock sleeve and cylinder without altering anything but the actual bore is just an over bore. big bore would mean you change your bore to the extent you need additional work done to reinforce your cylinder and possibly even a bigger jug for cooling purposes. that's why people purchase big bore kits because they come with already reinforced cylinders and what not. there are what people will refer to as big bore engines which are just that, an engine with a large stock bore, but that's talkin like big block small block with cars. you can have a small block engine with a big bore and long stroke that may equal the same cubic inches as a big block, however, it's still a small block just with a big bore and in some cases a longer stroke. you can have any size engine though with a big bore. hope that all makes sense.
Old Apr 17, 2007 | 10:30 AM
LT80's Avatar
LT80 Expert
Terminology eh....LOL
IMO, over bore is when the stock sleeve is bored. ie: my 250R with the stock cylinder bored a cpl times.
Big bore is when a aftermarket sleeve or cylinder is used. ie: my 250R with my 310 cylinder on it.
.80 over (2mm) is an overbore. [img]i/expressions/face-icon-small-smile.gif[/img]
baxy
Jan 16, 2004 02:14 AM
Colby
Oct 26, 2003 12:45 AM
pleasure4qt
Oct 23, 2003 05:44 PM
roosthrower
Aug 13, 2003 04:12 PM
GriffsFSR
Aug 2, 2000 10:51 PM
