Wheel doesn't spin straight
Old Apr 10, 2007 | 11:50 AM
hometheaterman's Avatar
Default Wheel doesn't spin straight
Ever since I've gotten my quad my right front wheel has also wobbled when spinning. I thought it was a bent rim so I replaced it and it still does it. Would it be a bent hub or is it most likely something else? I know the control arms have been smashed up a little but I don't see how it could cause the wheel to not spin straight.
Old Apr 10, 2007 | 01:15 PM
bradr's Avatar
it could be bearings inside the hub. i had the same problem with my ltz250.
Old Apr 11, 2007 | 12:10 AM
bombrider04's Avatar
If your front end isn't strait or if your tierod has play in it while riding this could be the culprit...Can you feel the wobble while riding?...If so I would say check your tierods and your steering components...Also if you have a bent rim or the wheel isn't ballanced this could be part of the problem.
Old Apr 11, 2007 | 12:39 PM
frotrk's Avatar
jack it up, spin the wheel and check for runout(wobble) at the rin, not the tire. if rim is ok then check the tire(may be bad tire). check the hub for bearing play. if tire,rim and bearing ok you have a bent hub.
Clark
Old Apr 12, 2007 | 09:54 PM
Brhodsie's Avatar
im voting maybe its the bearing you coulda smashed up pretty good
Old Apr 13, 2007 | 02:22 AM
Ok I was thinking the hub too but wasn't sure. It's done this since I got it. On dirt you can't feel it too much but can see it wobble and feel it a little but on pavement it's pretty noticable. Not soo bad you can't ride it but enough that it is noticable. It isn't the rim as thats what I thought so I replaced the rims and it didn't correct it.
Old Apr 13, 2007 | 09:52 PM
benzzyo5's Avatar
it's probably the wheele bearing this happened to me recently and i need a new one
Old Apr 15, 2007 | 05:14 PM
bradr's Avatar
its definatly the hub bearing. i had the exact problem. i waited to long and my bearings fell out and i had to buy a new hub because the inside was all gouged.
Old Apr 15, 2007 | 06:10 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
I have a new tire that does that. Seems as though the tire tread isn't straight. If you can see the rim isn't wobbling, it could be a bad tire. If it's a bearing you should be able to tell by jacking your ATV up and seeing if there is play in the wheel by trying to wiggle it side to side.
Buck
cody500ho
14
Aug 14, 2015 05:03 PM
WilliamBos
Aug 8, 2015 07:26 PM
toonces
Aug 5, 2015 05:55 PM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
