LT230E Problem
Old May 15, 2007 | 01:50 AM
82cruiser's Avatar
Default LT230E Problem
Its a 1990 and runs fine in neutral except for the high idle. It is either high or off. If you hit the throttle it will rev up and stay there for awhile( throttle is not sticking). Anyways the main problem is that when you put it in gear it revs up good to mid range and then bogs. All elect. components were checked and are good. Plug is a standard ngk. Gas is good and the carb has been through 6 times. Compression is at 120. No rear brakes so they aren't dragging. HELP GOD O HELP ME
Old May 20, 2007 | 04:38 PM
coted's Avatar
sounds like ur lackin fueal at some times them making up for it when its not needed....check on the throttle needle that screws on the top of carb..
Old May 20, 2007 | 06:21 PM
82cruiser's Avatar
tried it but it does not change the mixture that much.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
