ltz50 quad no power
Old Nov 30, 2007 | 11:21 PM
  #381
RIDE!'s Avatar
Default ltz50 quad no power
<div class="FTQUOTE"><begin quote>Originally posted by: lowlife
Hey RIDE! make sure you upgrade that stock airbox to either a K&N with the outerwear cover or a uni filter. The stock box will suck in the sand and destroy the engine.</end quote></div>
Thanks. I had a K&N on before but as soon as I pushed the throttle it went great, but bogged out way before the rev limit. I couldn't find a larger jet around here, so I put the stock back on. I'll remove that set screw and see how that works with the K&N. I noticed though the filter barely sits on the carb inlet......real close to slipping off if not tight enough, so I used the rubber piece from the plastic (like the photos) and used a 3/4" galvanized pipe to use between that and the filter. Used another clamp for the stock rubber side, everything fit perfect! Thanks for looking out.
Old Dec 1, 2007 | 12:25 AM
  #382
racing's Avatar
Can somebody show a pic of the head without the exhaust washer in it?Also I took my idle jet out and didint see a set screw,if there was a set screw under it how could the fuel get through?
Thanks for any help
Old Dec 1, 2007 | 02:40 PM
  #383
lowlife's Avatar
Go to this link http://www.flickr.com/gp/19349868@N05/62qU9w and you will see a pic of the pipe and head seperated with the washer there. Some people are letting me know that they too haven't had to remove a set screw while others are. Not sure why that is. I would assume that if bought new from the dealer they would all be set up the same.
Old Dec 4, 2007 | 01:12 AM
  #384
dmontzsta's Avatar
What is new guys? anyone install anything and ride yet?
Old Dec 4, 2007 | 01:15 AM
  #385
EdKatt's Avatar
not yet! It was really cold this weekend! Rainy and windy! I wasn't going out for anything! I might just wait to put the filter on when I get the pipe. I only want to mess with the carb once!
Old Dec 5, 2007 | 03:35 PM
  #386
tbirdsc50's Avatar
ok GUYS i put the CDI BOX ON TODAY OHMY OH MY HOLD ON THIS THING FLYS, EVEN WITH MY BIG *** ON IT , THE K&N HAS NOT COME IN YET , , I WILL SAY WELL WORTH THE $$$, SON, DAKOTA, WAS OUT THERE DOING POWER SLIDS,
my mods , 3 rollers, spacer, mods to stock exhaust, and CDI ,
Old Dec 5, 2007 | 03:44 PM
  #387
dmontzsta's Avatar
which CDI did you get? and just with the CDI you noticed a huge difference?
I am thinking of buying a CDI as the first mod, just to free up the top end some more. I am also leaning towards the LT90 CDI, since it is a factory Suzuki piece, a little cheaper and the aftermarket seems like it has had a few gliches. The only debate is which revs higher?
Old Dec 5, 2007 | 04:21 PM
  #388
tbirdsc50's Avatar
hi dmontzsta , DYNA, for 174.00 free ship, on ebay, the revs,r 8000,, stock 5000, huge difference, with few mods i have done . from what someone said a while ago, the 90 cdi did not let it run all out , and the rves if i remember right was 7500. ?.
Old Dec 5, 2007 | 05:08 PM
  #389
tbirdsc50's Avatar
OK I RAN IT UP THE ROAD , 25 MHP , , SO FROM 8 TO 25,
Old Dec 5, 2007 | 05:19 PM
  #390
dmontzsta's Avatar
nice, is it a flat road? and 25mph with you on it? what GPS do you use?
