lt 80 no power
Old May 19, 2007 | 01:31 AM
motox14's Avatar
Default lt 80 no power
I have a 91 lt 80 im having trouble, I have great power and ride for a few minutes and then it dont have any power want barly move,wait a few minutes and it comes back alive. It does this over and over. Any ideas?
Old May 19, 2007 | 10:36 PM
bombrider04's Avatar
I would start by cleaning out the carb and make sure you have enough gas and have the correct mixture...Clean out the jets making sure you can see light through the holes and it should help...If that doesn't work I would say you might be due for a new reed valve or your compression may be off, but I would clean the carb first and see if that helps along with a new spark plug and a cleaned filter.
Old May 20, 2007 | 11:43 AM
motox14's Avatar
I put a brand new carb in, new airfilter and new spark plug. same problem,i will try new reeds. Thanks for the reply.
Old May 20, 2007 | 06:54 PM
LT80's Avatar
LT80 Expert
It's either a plugged pipe or a coil problem.
Old May 23, 2007 | 01:21 AM
motox14's Avatar
I cleaned out the pipe, can i test the coil? and if i can how? Can it also be a bad spark plug cap?
Old May 23, 2007 | 09:34 AM
LT80's Avatar
LT80 Expert
The cap sucks at best. Duct tape it down and see if that helps. A NGK cap for a Arctic Cat snowmobile works great and never comes off.
You can test the coil and stator with an ohm meter but I do not know the correct readings. [img]i/expressions/face-icon-small-sad.gif[/img]
Old May 23, 2007 | 11:08 AM
hally's Avatar
lt80
we have a 06 lt80 and would like some advice on better springs and shocks for racing this bike.Lso a recommendation for alloy rims and tyres.
Hally
Australia
Old May 24, 2007 | 10:23 AM
LT80's Avatar
LT80 Expert
Hally,
Works are about the only sensable option for shocks. About $500 US for all 3.
I use Douglas wheels and cheap knobby tires.
16x6.5x8 for MX
18x6.5x8 for dunes,trails,etc.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
