'85 LT250R
Old Dec 30, 2000 | 09:10 PM
Lovmaraptor's Avatar
I am in the process of buying a LT250R. I was wondering if anyone has any common things to look for. Thanks!!!
Old Jan 4, 2001 | 01:05 AM
URnotRoscoe's Avatar
Check the swing arm for cracks around the pinch bolts. If you plan on jumping on hard pack plan on buying a stronger swing arm.
Old Jan 4, 2001 | 02:01 AM
dual-sporter's Avatar
check around the front shock mounts on the frame for any cracks, that's where a friend's broke.
also check:
front & rear suspension for play(looseness in any way- side to side, up/down, etc..)
any suspension mounts for cracks,
suspension components for bent parts, (on '85-86 q-racers, the swingarm for cracks arount the axle carrier)
frame(esp. underneath) for bent tubes & broken welds
steering for play(very small amt is okay)
rear axle bearings for play,
air filter condition & mounting(indicates motor condition & how the owner cared for it)
coolant in radiator
tranny oil... (if its white/grey you have water in it, any metal shavings, etc.. is bad)
if you have the tools, do a compression check.
finally...
ride it, listen to how the motor runs, & decide if you are ready to cope with whatever problems may be there.
Old Jan 6, 2001 | 10:51 PM
itsshemp's Avatar
DEFINITLY look for cracks on the swingarm!!!!!!!!
This is a VERY common problem with the 85-86 LT's.
87-up had the box type housing. MUCH better!!
My brother used to have an 86, and we had to reinforce the pinch area of the swingarm to avoid a very expensive replacement.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
