diesel in gas tank
Old Aug 11, 2007 | 05:43 PM
tomdoro's Avatar
Default diesel in gas tank
I have two problems.
1. Son unknowingly added about 1 gal of diesel to his 2000 Quadmaster 500.
Other than draining the fuel, changing the filter, is there anything else I need to do.
2. The push button to start the engine went bad and was replaced with a new switch. After 4-5 starts when the button is pushed, the engine starts but the starter continues to run. Would the problem be the starter or relay? Or perhaps just a good cleanin of the starter.
Any help would be greatly appreciated.
Old Aug 11, 2007 | 10:23 PM
velocyraptor's Avatar
cool
Old Aug 11, 2007 | 11:20 PM
KINGQUAD450's Avatar
Draining the tank is about your only option and by far the best option. I would even fluch the tank out with some gas before tring to restart it
Old Aug 12, 2007 | 03:57 PM
HeftyLefty's Avatar
Be sure to clean the carb and float bowl of diesel fuel. On the starter issue-It could be your 'new' switch is cheaply made and is hanging. The contacts could be sticking due to too high a current being put through the switch. Or the they could just be defective.I don't know what you have, but when I need a pushbutton momentary switch, I always get a 12 volt 10-30 amp rated one from an auto parts store instead of a cheapie from RadioShack.
Another cause that comes to mind is the bendix (the clutch that throws out the gear to engage the flywheel), is old and is hanging.What did the starter do before the switch failed?. If it was OK, I would suspect the switch. If the starter was acting up and you replaced the switch thinking it failed, I would suspect the starter. Based on what you say, I think the relay is OK, relays either work or they don't.
Old Aug 12, 2007 | 04:55 PM
tomdoro's Avatar
hefty lefty thanks for your response. Will check as you recommended. I also ride a king quad 450 in wv. Love it so far
TXMinuteman
Oct 6, 2015 06:43 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
