help LT80
Old Aug 14, 2007 | 06:03 PM
turkeythigh's Avatar
Default help LT80
i need help i cant find anything tellling me what the mixture is and the injector was not working so i took it off. just rebuilt the engine. need to break it in with proper mixture. can any one help?
Old Aug 15, 2007 | 09:57 AM
LT80's Avatar
LT80 Expert
Default help LT80
Did you remove the lil black plastic piece that drives the pump ?
32:1 with a petroleum base oil for break in.
A quality synthetic (Torco GP-7 or Klotz R-50) at 32:1 after break in.
If you used a Zuki piston, break in will be at a minimum (basically run it).
If you used a weisco piston, a very careful break in is required.
Old Aug 20, 2007 | 08:47 PM
CRF-Ridaz07's Avatar
Default help LT80
when i try to star my lt80 it wont even make a noise, what should i do
Old Aug 21, 2007 | 10:04 AM
LT80's Avatar
LT80 Expert
Default help LT80
The other post pointed you in the right direction.
We'll go from there. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 22, 2007 | 03:14 AM
1128633636's Avatar
Default help LT80
Start with the basics (battery). Did you pop the main fuse ? Under the seat right side, just pushit back in...check wires etc..
Old Oct 3, 2007 | 01:29 AM
ATC250RRider209's Avatar
Default help LT80
hey LT80 i was wondering if i can use hp 2 stroke oil for my lt80
Old Oct 3, 2007 | 05:31 AM
Default help LT80
yeah any 2 strok oil should work but some are better than others.
right now because i was too cheap to go buy oil im using chin saw oil...
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
