LT80: R&R'd clutch rollers: Now clutch is too tight
Old Sep 4, 2007 | 12:15 AM
bmiliate's Avatar
Default LT80: R&R'd clutch rollers: Now clutch is too tight
I just R&R'd the rollers in my LT80's front clutch. Had four (thought 3) in it before, and it ran well, but the clutch began to slip sooner than I wanted, so this time, I went to five rollers. Now, the LT80 bogs bad until it gets on the pipe. So bad that it won't get started moving on a decent incline. I used an electric impact wrench to tighten it. Is my problem too many rollers (DG pipe) or too tight?
Thanks!
Old Sep 4, 2007 | 01:44 PM
LT80's Avatar
LT80 Expert
It's the rollers.
It should be tight. You did re-install the big washer, right?
Old Sep 4, 2007 | 02:21 PM
bmiliate's Avatar
LT80,
Thanks, as always for your quick reply. I installed the front clutch assembly, then the washer, then the bolt. Is this correct?
Also, is it OK to use an impact to tighten?
Old Sep 4, 2007 | 04:02 PM
LT80's Avatar
LT80 Expert
Yes you indeed use an impact wrench. [img]i/expressions/face-icon-small-smile.gif[/img]
The washer I mentioned: your installing the roller hub (variator) then you put the spacer thru that part, then a big washer,then the outewr clutch face,thin spring washer, then nut. The big washer that the belt rides on is what I'm talkinbg about.
Old Sep 4, 2007 | 05:32 PM
bmiliate's Avatar
Yes, I did install the big washer - thanks for checking. I guess it's the extra roller that's causing the bog, like you said. So, is the DG Pipe more of a top-end pipe? Just wondering, since stock the LT has 6 rollers.
Thanks.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
