03 Z400 Rear Bearings
its not that tough of a job ,make sure you have the right bearings and seals, i had one of the big bolts snap off on me when mine was coming a part ,other than that little miss hap its an easy job. i would leave the seals on the bearing you may find the inside seal has been removed ,thats a bad idea unless ya can pump grease in to the housing ,but you cant so leave the seals on the bearings . every thing goes out the right side .
07-15-2015 02:07 AM
