shifting problem lt185 "84"
Old Sep 23, 2007 | 06:29 PM
know nothing's Avatar
Default shifting problem lt185 "84"
old clutch broke,replaced with new.Can shift thru gears with cover off,but when cover is put back on can only get it into one gear and no longer shifts. anyone with any idea what could be my problem.Help in fixing would be greatly appreciated and my son would like that too!
Old Sep 23, 2007 | 09:04 PM
CWO4GUNNER's Avatar
If you can shift through the gears with the new clutch ok without the cover but not with something is wrong in either your assembly or a tolerance issue with the parts. You should recheck all your work and the parts against specifications with the shop manual. My point is that if its truly still broken it should not work at all.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
