LT80 Boyesen Reed Question
Old Dec 11, 2007 | 11:04 PM
peanstein's Avatar
Default LT80 Boyesen Reed Question
i have a 95 lt80 and was changing the stock(i think) reeds to boyesen PN# 11-6064 labeled for lt80 87-00 and also for ksf/kfx80
my ? is this:
stock reeds have a split in the middle, is made out of metal and matches the reed cage and only has the reed itself.
the boyesen has the reed and i guess what they call big reed. it is also about 1/4" shorter than the stock one. see pic.
do i use both and will it affect performace since the boyesen does not have the split and is smaller?
also, from experience, will i need to rejet? i already am using a 97.5 main since i have aftermarket exhaust.
see picture of old and new reed
thanks in advance
Old Dec 12, 2007 | 09:42 AM
peanstein's Avatar
ok, got an answer. they are 2 stage reeds and are correct. its been a while and have forgotten about a lot of things.
Old Dec 12, 2007 | 10:35 AM
LT80's Avatar
LT80 Expert
No, you shouldn't have to re-jet. Isn't your plug black?
Old Dec 12, 2007 | 10:37 AM
peanstein's Avatar
i have not put them in yet. will find out by tomorrow though.
thanks and we will see
Old Dec 12, 2007 | 10:51 AM
LT80's Avatar
LT80 Expert
I was refering to the 97.5 jet as it is running before the reed change. Seems way fat to me.
Just curious. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 12, 2007 | 11:09 AM
peanstein's Avatar
oh, no that was what i used to support the pipe i put on. if memory serves right, stock was 92.5 and tried a 95 but still went a bit higher. ill have to go back a recheck since that was 6 years ago and now that i think of it, i placed the fatter jet to be safe since i really never did a full plug check after the 97.5 jet was put in.
i tried looking for the 95 i had but cant find it so im stuck till i go out and buy another 95.
thanks
QuadRiders
Oct 22, 2015 04:13 PM
bigred20653
Oct 2, 2015 10:05 AM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
