LTZ90 Roller weights?
Old Dec 23, 2007 | 09:45 AM
Outof$'s Avatar
Default LTZ90 Roller weights?
Can someone tell me if all the weights are the same grams? I took the limiter spacer out yesterday, while doing it all the weights fell out. I picked them up then randomly put them back in thinking they were all the same weight. This morning I am not sure. Instead of taking it back apart I was hopeing someone could ease my mind and give me the answer.
thanks
Old Dec 23, 2007 | 11:01 PM
AIRMOBILE101's Avatar
Yes, they are all the same. You can run only three of them if you want more torque. Just make sure you evenly space the three in the six slots.
Old Dec 24, 2007 | 12:14 PM
LT80's Avatar
LT80 Expert
3 is too little imo. The LT80's ran 4 rollers w/o problem but the 4 stroke may act differently. If stock, just leave the 6 in. [img]i/expressions/face-icon-small-smile.gif[/img]
Yes they weigh the same.
Old Jan 3, 2008 | 08:50 PM
Outof$'s Avatar
LT80, I just cant help but tinker. If I replace the current rollers with lighter ones do I gain low end and lose top end?
I know you said leave it alone but is it worth a try to find out? We dont ride wide open at all. He may once or twice had it all open so top end is not needed. We ride mostly trails with a lot of hills and mud and was looking for more grunt. Any suggestions?
Old Jan 3, 2008 | 08:59 PM
LT80's Avatar
LT80 Expert
hehe, I understand. [img]i/expressions/face-icon-small-happy.gif[/img]
I'd try removing 2 of the rollers and see the effect. This allows for a higher stall speed which is what your looking for I think.
Old Jan 3, 2008 | 09:23 PM
Outof$'s Avatar
I am sure you already know but the weights are in groups of two. If i remove two of them obivously (sp?) it seems they will be uneven 2-1-1. Do you think that will be a problem.
Old Jan 3, 2008 | 11:25 PM
LT80's Avatar
LT80 Expert
4 long term is a bad idea. To test the responce with 4 shouldn't hurt. If the result is what you desire, then you can buy the different weight rollers.
Old Jan 4, 2008 | 09:12 AM
Outof$'s Avatar
Ok, I got you now. I wasn't thinking that way. I am going to try it and If you care I will tell you what I come up with. Thanks for the advice, I know that this has come up under other machines but I like to see it for model specific.
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
