what kind of two stroke oil is good
Old Jan 16, 2008 | 05:04 AM
iceracer01's Avatar
Default what kind of two stroke oil is good
what kind of two stroke oil is good for a lt250r with a new weisco piston and a fmf fatty pipe thanks
Old Jan 16, 2008 | 10:23 AM
gogoquadzilla's Avatar
all i've ever used is bel ray h1r at 50:1 but thats not to say that anything else is bad
Old Jan 16, 2008 | 12:10 PM
LT80's Avatar
LT80 Expert
Torco GP-7 is my favorite to keep a motor well lubricated.
torcousa.com
Klotz R-50 is my 2nd choice.
Old Jan 16, 2008 | 09:38 PM
Viperboy's Avatar
Lots of good 2 stroke oils. I prefer Amsoil synthetic 2 stroke, but as long as you have your pre-mix dialed in, you can't go wrong with any of the above products!
Old Jan 17, 2008 | 04:27 PM
WAATV's Avatar
What are the tradeoffs between "normal" and synthetic oils in Suzuki two stroke engines? I've heard synthetic burns cleaner and thus doesn't leave carbon deposits. I've also heard that liquid dinosaurs lubricate better. What's the real story?
Thanks!
Old Jan 17, 2008 | 05:13 PM
TLC's Avatar
TLC
Dinosaurs one and only advantage is Price, period, after that its a down grade compared to Full synthetic. That goes for 4 stroke oil,gear oil,chain case oil and grease as well.
Old Jan 17, 2008 | 05:26 PM
WAATV's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLCDinosaurs one and only advantage is Price, period, after that its a down grade compared to Full synthetic. That goes for 4 stroke oil,gear oil,chain case oil and grease as well.</end quote></div>
At the rate my son's LT-A50 burns oil (which is to say, hardly any at all), I think I'll move to synthetic. I'd like to keep that engine as clean as possible. We bought a quart of NAPA 2-stroke oil when we got the machine and he hasn't yet burned through that first bottle yet despite many, MANY hours of operation. The incremental cost of synthetic won't be significant.
Thanks!
Old Jan 18, 2008 | 03:28 AM
iceracer01's Avatar
what about Yamaha lube 2 stroke is that any good does it burn clean?
Old Jan 18, 2008 | 10:58 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: iceracer01
what about Yamaha lube 2 stroke is that any good does it burn clean?</end quote></div>
Read the bottle if it does not say "Full Synthetic" any where on it, than its not the best available.
Old Jan 18, 2008 | 07:50 PM
zaptoad's Avatar
When I was young and played a lot, I always ran name brand oil. I played with mix ratios and learned a lot too. Now I only run Wal-Mart oil( an incognito name brand) at 40 to 1. I live in the country and don't have time to mess with different mixes. Everything I own runs exactly the same mix and most importantly, runs good with no confusion. Half a quart to 5 gallons, full quart to 10; plus 1 oz of Iso-Heet per gallon to keep the water out. Word of caution here, only run red Heet cause it won't separate the oil out of the gas. JetSkiis (Kawasaki & Yamaha), chainsaws(Husky, Echo, & Stihl), weedeaters(Stihl, & Kaz), snowmobiles(Yamaha, Polaris, & Artic Cat), Motorcycles(Bultaco, Honda, Husky, Kawasaki, Yamaha, CZ, & Suzuki). Every dealer wants you to run only thier brand, and sometimes even threaten with the warranty issue. I just run the same thing in everything. Some of this stuff I have been running for over 15 years now with no problems. FWIW.....
