lt 80 help
Old Jan 22, 2008 | 01:54 AM
babygirl712's Avatar
Default lt 80 help
My lt 80 will crank over but will not start, I have changed the battery as well as the spark plug and put it a new piston on it yet it is still doing the same thing any one have any suggestions? Thanks
Old Jan 22, 2008 | 11:42 AM
LT80's Avatar
LT80 Expert
Default lt 80 help
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
Is it getting fuel (wet plug)?
Is it getting spark?
Old Jan 22, 2008 | 03:14 PM
Default lt 80 help
I am on both but the compression is only up to 80 and it wont start at all you just her it trying to crank over but it wont fire up. got any other ideas? thanks
Old Jan 22, 2008 | 06:14 PM
LT80's Avatar
LT80 Expert
Default lt 80 help
80 isn't near enough (120-130)
Tell me about this new piston..Are you saying that you took the cylinder and had it bored to the new size, or you put a new piston in the cylinder w/o the bore?
Old Jan 22, 2008 | 06:52 PM
Default lt 80 help
No we just replaced the stock piston, do you think it would be the cylinder? How can you tell if the cylinder is bad are there any obvious signs?
Old Jan 23, 2008 | 10:36 AM
LT80's Avatar
LT80 Expert
Default lt 80 help
The obvious sign is no compression. Even a new piston that isn't broke in to the cylinder would not be that low.
You need the next size piston and the cylinder bored to it.
Use Suzuki pistons/parts.[img]i/expressions/face-icon-small-smile.gif[/img]
