Eiger carb
Old Jan 23, 2008 | 11:03 PM
Scott267839's Avatar
Default Eiger carb
My Eiger has not idle right since last spring. I have clean my carb atleast 4 times currently 5. This time I had it soaked in what they clean car carbs in.
I noticed this time that the needle jet is missing. I'm not sure if it fell out during it being soaked or if it has been missing. I have never removed it. So I do not know it it just feel out this time or if it has been missing for some time. With it missing would it effect idle?
From what I have read it effects the mid to high throttle range. In the past it ran fine above idle.
I'm currently waitting on my new needle jet.
Any input on how a missing needle jet would effect the running?
Scott
Old Jan 24, 2008 | 04:46 AM
hondabuster's Avatar
Default Eiger carb
Youre right about it effecting the 1/4 to 3/4 throttle . It should just idle fine without a needle installed. It should also idle just fine without a main jet too.
Did you remove the pilot jet, and make sure the center hole is clean? Replace it if youre unsure. How many turns out is the mixture screw?
Old Jan 24, 2008 | 05:58 AM
Default Eiger carb
I have the needle it is the needle jet that is missing. They call the needle, jet needle, and the jet for needle, needle jet.
Yes I have removed the pilot jet and cleaned it. I have had the mixture screw anywhere from 1.5 to 4.5 turns out.
Old Jan 29, 2008 | 02:48 AM
Default Eiger carb
I got my needle jet today. There is a very loose fit between the needle jet and jet needle. Is this normal? I looks like some fuel would come out during idle because of the loose fit between the two.
Old Jan 29, 2008 | 01:04 PM
Default Eiger carb
Its not supposed to fit like a cork in a bottle. The protusions on the bottom of the slide, keep gas from coming out at idle speed(throttle slide closed)
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
baysport
Jul 23, 2015 11:37 AM
Aitch
Jul 21, 2015 09:40 PM
