LTZ400 aka Battery Killa
Old Feb 4, 2008 | 01:38 PM
voz's Avatar
voz
Default LTZ400 aka Battery Killa
Gentlemen,
I have a 2004 LTZ400 battery went dead, Went out and got a new fully charged battery, slapped it in went to www.buscobeach.com and she ran like a champ all day.
Loaded it up took about 1 hr ride home and when to start it to unload it and she acted as if battery was dead? WTF..
Put it on my battery tender for about 1 hour and she fired right on up..
What gives?
p.s. any online manuals for this thing?
Old Feb 4, 2008 | 01:47 PM
BAIR's Avatar
OK you have two possibilities here, a bad alternator or a slow discharge in the system.
From the way you describe the problem I'd go with the bad Alternator. The good news is it's easy to check.
Turn the ATV on and put a Voltmeter accross the battery. You should be reading 14-15 volts from the Alternator to charge the battery.
If you don't have the 14-15 Volts the charging system is at fault, if the power is there... you have other concerns...
Check the Battery connections for tightness & Corrosion... after that you are on your own to find a bad connection, loose wire or circuit that is drawing too much power.
Good Luck!
Old Feb 4, 2008 | 03:07 PM
voz's Avatar
voz
Hmm that at can do!
Will post my findings when I get off work
Old Feb 4, 2008 | 07:31 PM
voz's Avatar
voz
reading is 14-15 range..
damn, now I have to follow the harness and see what I find
Old Feb 5, 2008 | 09:11 AM
BAIR's Avatar
Yes; now it gets interesting BUT remember the KISS rule.
Keep It Simple Stupid!
Start with the battery terminals, do they tighten down? Sometimes the bolts don't catch the nuts and you get a poor connection and bad charging results.
Then work your way out to the other connections, if you aren't comfortable doing this ... that's what your dealer is for.
Old Feb 6, 2008 | 08:10 PM
voz's Avatar
voz
as far as I can tell all connections seem to be in order...
what else?
Old Feb 7, 2008 | 10:57 AM
warrior226's Avatar
Does the solenoid click? Or are you getting nothing? May have to grab a service manual (which I still need to do) to check the wires coming out of your stator, to see if it's putting out the required voltage.
Old Feb 7, 2008 | 12:09 PM
voz's Avatar
voz
10-4 I have the Cd version of the manual that I got from a friend{not the best }.. trying to locate the book locally!
Old Feb 10, 2008 | 10:06 AM
voz's Avatar
voz
Upon further inspection I found this plug sitting there and I have no idea where it goes to.. Could it be causing my problems..??
Also, Where does the hose from Fan go to? noticed it was missing..
and here a few pics for good measure.
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
