New member with questions
<div class="FTQUOTE"><begin quote>Originally posted by: jaybeecon55
Welcome to the forums. That's a good deal for a low milage bike with a winch. The Eiger is a good all around bike, you'll be happy with it.
Here's some stats form the book:
Fuel - 4.0 gallons
Oil - 3.4 qts (I've always noticed it being closer to 4 qt.) Below 5 degreesuse 5W-30 oil. Normal is 10W-30 with 10W-40 in hot temperatures
Dif Gear oil - 10.1 oz.
Gear oil 8.5 to 11.8 oz. SAE90 with a GL-5 rating
Jaybee</end quote></div>
Wow 4 quarts for oil thats only 1 less quart than my truck.? Thats double what I need for my ATV. Must be a advantage in having a big sump though ,like longer periods of time between oil changes or something?
Fuel - 4.0 gallons
I think they must have made the large capacity for additional oil cooling. The Eiger is a big air cooled bike with a fan and an oil cooler.
55 oval - If you like water over the wheels then just wiat until you hit some deeper streams. I've had mine out where the only thing above water was part of the racks and the handlebars. As long as you move forward and keep the snorkle area dry it will keep going.
Jaybee
Jaybee
haha thats awesome, Im hoping to do some more water crossing when the weather gets warmer.
As for the oil, last night I did a quick ride and I noticed on a steep hill if I rolled back a bit and hit the gas, it felt like it was slipping and I would hear like a loud squeek, then it would catch and go up the hill. I didnt notice it doing this before I changhed the oil, so I bought some Valvoline 4 stroke for motorcycles and I'm going to put that in. It said it had superior protection for wet clutches so Im assuming its the right stuff. Damn expensive too so it better be.
#16
