just got a 03 z400 and i have a stupid question about it
Old Mar 21, 2010 | 10:04 PM
texas poser's Avatar
Originally Posted by Scootergptx
If you have, or want to get a gmail account, I can send you the factory service manual for it.
does this offer still stand?
I'm trying to figure out a starting problem
Old Mar 24, 2010 | 04:01 PM
Sand Hog's Avatar
If there are no lines engraved on the stick then the stick should have a flat spot on one side of the stick. The bottom (tip end) of the flat spot on the stick serves as the add line while the top end serves as the full line. Be careful adding oil to your bike. be sure to start it and run it up to driving temp then shut it down and wait about 30 seconds then check the oil just like you would for your car for an accurate measure of the oil in your crank case. In a cold bike the oil settles and you can overfill your oil without knowing it.
As for an owners manual try looking online for a downloadable owners manual.
Old Mar 24, 2010 | 04:03 PM
Sand Hog's Avatar
The wifes LTZ-250 has a tough time starting.. she also has gear shift issues until the engine is warmed up all the way..The bike shop suggested using a lighter oil 20-50 or a little lighter and that should take care of the starting & gear issues.
Old Mar 26, 2010 | 12:09 AM
2strokezilla's Avatar
sometimes it is tuff getting a good reading on the dipstick on Z400 because not all your oil goes back into res tank I know because I have put oil in thinking it was low only to have it overflow out of tank next time I chk it
NewGuy2481
Oct 6, 2015 05:54 AM
bigred20653
Oct 2, 2015 10:05 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
1ArmBandit
Sep 8, 2015 08:59 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
