'03 LT400Z running perfect when parked, now won't run unless choked
Old Apr 13, 2008 | 11:02 PM
  #41
hondabuster's Avatar
Default '03 LT400Z running perfect when parked, now won't run unless choked
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
I don't think it would work wonders, but worth a shot I guess. It might clear 'something' up 'somewhere' in the carb anyway.
I've had pilots so plugged up that 125psi air wouldn't clear it. I had to use a guitar string to get it clean. [img][/img]</end quote></div>
Good idea on the guitar string, do you know the diameter of the string, and how small they go? Was that the nylon or steel string?
Old Apr 14, 2008 | 08:53 AM
  #42
JustRandy's Avatar
Steel. I think it was the E string (.011 inch). Sometimes the B string works too (.015 inch). They make smaller strings (.009 and maybe even .008). Not sure the absolute smallest, but your neighborhood pawn shop would probably have a decent selection. The rest of the strings I got are: G (.022), D (.032), A (.042), E (.052). I paid $9 at the pawn shop for the pack. The smaller the strings though, the more they cost.
One time I needed a wee bigger pilot... So I took one of the small wound strings and stood on one end and pull it tight with one hand. Then I took the jet and moved it up n down on the string winding to open to pilot jet up some. It worked, but even after considerable time filing away at the jet, I still couldn't step up to the next string.
I'm into all that backwoods redneck engineering. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 14, 2008 | 11:00 AM
  #43
Its tough to find something that small. Ive been using one strand of 20 gauge stranded wire, and thats too easily bent.
Thanks for the tip.
Old Apr 14, 2008 | 07:56 PM
  #44
JustRandy's Avatar
Yes, I looked thru my box of misc wires looking for something small enough to fit in a pilot jet. Everything I found that was small enough to fit, wasn't stiff enough. Then it dawned on me about the guitar string.
Watching any mythbusters lately?
Old Apr 15, 2008 | 09:19 PM
  #45
JustRandy's Avatar
Hey, I was wondering if you can help me out. I just got my jug back from Kustom Kraft and it came with special instructions. It reads "It's crucial that cranking pressure not exceed 170 lbs. Check compression before break-in and take steps to correct compression ratios that are too high. (Add base gaskets or increase head volume)."
I don't understand why they recommend this. The last time I took a reading (before I got the big bore kit), my compression was over 200 and I was going to deck the cylinder on top of it. I never heard this before. Can you help me understand why they say this?
Old Apr 15, 2008 | 09:46 PM
  #46
Watching any mythbusters lately?</end quote></div>
I searched ebay, and found some wires, but havent ordered any yet. I dont need the full set, just the small string...either .009 or .01". Im glad you shared that information.
Been watching new releases, I really liked no country for old men....have you seen that one? Also lions for lambs was good.
Ive already gotten all the mythbusters from netfix, and the local rental, so now the only time I catch mythbusters is when I go out of town, and have cable in the motel room.
Old Apr 15, 2008 | 09:49 PM
  #47
I don't understand why they recommend this. The last time I took a reading (before I got the big bore kit), my compression was over 200 and I was going to deck the cylinder on top of it. I never heard this before. Can you help me understand why they say this?</end quote></div>
I wish I knew, and if you find out, Id like to know. I bet if you call them up, they'd be glad to let you in on whats going on.
Old Apr 15, 2008 | 10:06 PM
  #48
JustRandy's Avatar
I'll try to call them tomorrow and find out. Maybe its a heat thing. The paper also says to go up 4 jet sizes on all jets and richen the needle some. That indicates to me that heat is a big concern with them.
Old Apr 15, 2008 | 10:12 PM
  #49
JustRandy's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hondabuster
I searched ebay, and found some wires, but havent ordered any yet. I dont need the full set, just the small string...either .009 or .01". Im glad you shared that information.</end quote></div>
Even the trimmings from someone that just restrung his guitar would work for you. Usually, I cut off a good 6 inches or more and toss it out.
<div class="FTQUOTE"><begin quote>Been watching new releases, I really liked no country for old men....have you seen that one? Also lions for lambs was good.</end quote></div>
No, I haven't seen many new releases. The last one I saw was the Will Smith one... I am Legend. It was ok, but a virus making people have super human strength and that was too much for me to believe.
<div class="FTQUOTE"><begin quote>Ive already gotten all the mythbusters from netfix, and the local rental, so now the only time I catch mythbusters is when I go out of town, and have cable in the motel room.</end quote></div>
I haven't caught them on tv lately either. Not sure if I just miss them or if they quit showing them so much.
SOLOLUCKY
Oct 4, 2024 09:09 PM
chinkapin
Jul 14, 2016 06:58 AM
BEEFKING69
Jun 17, 2015 12:38 AM
jayking232003
Jun 9, 2015 02:54 PM
neilbedwell
May 31, 2015 11:11 AM
