chain problem
Old May 12, 2008 | 08:00 PM
zz8t's Avatar
Default chain problem
ok oi have 2 atvs a 1988 lt230 and a 2001 yamaha warrior i have the same problem on both of them the chain falls off all the time on both of them. they both
have tight chains when i start riding and wheen i end riding so i dont know how they can fall off so much. i thought it was where/the way i ride but the same thing happens to my brother when he rides them and when i ride my friends the same way the chain stays on. i asked the dealer he said check all the barrings so i replaced them all still happened so i had them profesionally replaced(the guy who did it said it was a waste of time the old ones were fine) i dont know what to do should i get chain tensioners or is that just a bandaid on a broken arm
im going to post this in other sections to get more ideas thanks
Old May 12, 2008 | 10:07 PM
mudgeek's Avatar
what shape are the sprockets in? are the teeth full size or are the tops worn off
Old May 13, 2008 | 07:50 AM
zz8t's Avatar
the sprokets are flat when i lay them down and the teeth all look good
Old May 13, 2008 | 08:19 AM
mudgeek's Avatar
When is the last time you changed the chain and sprocket because your problem is indicative of worn parts
Old May 13, 2008 | 08:22 AM
mudgeek's Avatar
the teeth may look good but if you lay a new sprocket over top you can see how much they are really worn
Old May 13, 2008 | 09:09 PM
zz8t's Avatar
i look into that thanks
Old May 14, 2008 | 09:33 AM
LT80's Avatar
LT80 Expert
You do know that you adjust the chain tension with the rider on the machine...
Old May 14, 2008 | 03:53 PM
zz8t's Avatar
yea but thies both have two diffrent riders (me and my brother) im 160 and my brother is like 115 i tried to find even ground but it just keeps falling off (it falls off a lot more for him than me)
Sjrpp
May 2, 2023 03:59 PM
Firefighter400
Oct 8, 2022 06:38 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
