2002 LT80 ...no power..Help
Old Jul 21, 2008 | 09:55 AM
LT80's Avatar
LT80 Expert
Default 2002 LT80 ...no power..Help
<div class="FTQUOTE"><begin quote>Originally posted by: sbp72
would the cdi cause it to do this???if the cdi is bad woulnt it not start at all????</end quote></div>
Anything can happen,,right? [img]i/expressions/face-icon-small-smile.gif[/img]
Sometimes you need to remove the flywheel and sand it and the stator to make things work.
Old May 5, 2009 | 05:23 PM
springtuckyn's Avatar
Any info on this? My 03 runs great for a day or two, then bogs. I drain the bowl, and it runs great for another day or two... ???
Old May 6, 2009 | 07:08 AM
LT80's Avatar
LT80 Expert
Draining the bowl will not get the crud out. You need to remove the carb and do a proper cleaning.
Old May 29, 2009 | 03:51 PM
lackin199's Avatar
I Know this an old post but if you havent fixed it yet try taking off of the fuel regulator and clean off of the fuel filter mine did the same thing until i cleaned mine and now it workes like it was brand new
95wolv
Sep 27, 2024 12:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
byronman
Sep 6, 2015 06:34 PM
