03 vinson
Old Jul 19, 2008 | 09:45 PM
ADAMSQUAD's Avatar
Default 03 vinson
hi, my buddy has an 03 vinson with 1500km on it and it idles and runs well with all power. but i notice when he give it some throttle and is driving it it is smokng out blue. and he has to alwys check his oil and add some. what could he do to fix this?
Old Jul 20, 2008 | 06:14 PM
BradW's Avatar
Default 03 vinson
Well, I'd say it's burning oil. It's most likely either the valve-seals or the rings. If it hasn't lost any power I would guess the valve-seals.
Old Jul 20, 2008 | 11:16 PM
270quadsportguy's Avatar
Default 03 vinson
oil ring could be gone and it still run fine but smoke
Old Jul 21, 2008 | 12:39 AM
ADAMSQUAD's Avatar
Default 03 vinson
is this something that should be fixed?
Old Jul 21, 2008 | 12:44 AM
TLC's Avatar
TLC
Default 03 vinson
1500km=930 miles,no way a engine should need rings at that low mileage unless it was run at very low oil level .
Old Jul 21, 2008 | 09:50 AM
camozuki's Avatar
Default 03 vinson
My guess is he sunk it and got water in the engine causing the rings to be washed. The Vinson's have a nickelsil (sp) coating in the cylinder and the rings are designed to wear before the cylinder. He needs to put new rings and piston in it asap. Its only gonna get worse.
Quadmaster00
Jun 11, 2021 08:54 AM
panicmanic
Aug 11, 2015 06:50 AM
Sylvain97378
Apr 10, 2002 10:44 PM
markdf
Mar 18, 2002 02:23 AM
Phoneguy
Jan 8, 2002 03:34 PM
