lt250r vibaration
Old Oct 14, 2008 | 02:28 AM
gilblt250r's Avatar
Default lt250r vibaration
i just recently bought a 92 250r got it running today rode it a few times and noticed it vibrated really bad and was wondering if anyone knew any good ways to get some of it out
Old Oct 14, 2008 | 12:59 PM
theCATman's Avatar
Is it really bad?, like when you wind it up & the bars shake so severely that it's hard to hold onto..... I have bad news for you, either the crank bearings are out of it, or the counterbalancer is broken or it's bearing is shot too.
if it's just a little "tingle" so to speak, get a larger & softer set of grips. Like gel grips or Oury "block" grips.
Old Oct 14, 2008 | 02:45 PM
gilblt250r's Avatar
the motor is fresh so i dont think its the crank bearings it runs good and makes no noise just alot of **** is old and worn out i guess was thinking about putting some rubber on the motor mounts that will hopefully cut some of it out
Old Oct 14, 2008 | 04:18 PM
RK's Avatar
RK
Check that all 3 counterbalancer marks are lined up.
Q
Old Oct 15, 2008 | 03:13 AM
this guy's Avatar
Good call by Rk, I must ask is this your first old school 2 stroke, cause they do vibrate a lot. That being said, just make sure everything is tight, my 500 even shook it's kick starter bolt off.
Old Oct 15, 2008 | 12:03 PM
RK's Avatar
RK
They don't vibrate hardly at all if put together correctly.
Q
Old Oct 15, 2008 | 03:09 PM
this guy's Avatar
I'm just saying compaired to the modern 4 strokes where you can't tell if they are running or not.
Old Oct 16, 2008 | 02:42 AM
gilblt250r's Avatar
it is the first one i have owned but not ridden i have ridden a few trx 250r but they didn't shake nearly as bad as this its pretty damn bad it shakes the plastic off and makes the nuts back off everywhere that dont have a carter pin
Old Oct 16, 2008 | 03:41 AM
rockrider's Avatar
My 250 vibrated a sh!tload more than my KFX 400. The 400 didn't vibrate at all.
Old Oct 16, 2008 | 12:30 PM
RK's Avatar
RK
I already gave you your answer...........
No offense, but the other guys are giving you opinions
I have been building the Quadracers for 20 years and have built the fastest Quadracers on the planet......period.
Q
