New dude with few problems
Old Nov 23, 2008 | 09:11 PM
Tehhammer420's Avatar
Default New dude with few problems
Whats going on guys. New to the site thougth id check it out. I have no clue about ATV's i just bought one it's a suzuki quad sport 250 Not sure of the year im pretty sure it's a 04 or somthing. Anyways bought it off of some people that didn't really give a **** about it. The area where the key and what not should be are just 3 wires tied together. Anyone know where i can get a part to put their. 2nd and most important. The electric start will not work. The batter that was in the wheeler when i got it was trash couldn't even light a light bulb. So i bought a new batter and hopfuly that will take care of it all ... If that don't work where should i look next. Push starting it is gettin old... All info would be great like i said im a noob to ATV's
Thanks Hammer
Old Nov 23, 2008 | 10:20 PM
cherokee99's Avatar
http://bikebandit.com/
is a good place to get OEM parts, like a new ignition switch. just hit OEM parts and fill in the make n model of your ATV. also a good place to get a shop manual, that is the best investment you can make IMO.
try a new battery, if not then you can start looking at connectivity of the switch n motor with a volt meter.
welcome to the forum, and those little quadsports have been around forever. a great mechine!
Old Nov 23, 2008 | 10:28 PM
Glad to know. thought it would be a good first wheeler for me my wife and my daughter. Needs some new tires, I have a pic but says the pic is to big to fit. Blah. Thanks dude for the reply, I'm gonna be on here alot. And ill def get that manual for it. Like i said im not sure on the year but alot of poeple say 04
Old Nov 23, 2008 | 10:38 PM
cherokee99's Avatar
im pretty sure they didnt change much over the years. you should be able to find a manufacturers plate on the bike, ther usually on one of the front vertical frame rails. try looking there!
Old Nov 24, 2008 | 08:54 AM
Battery in and still no electric start. where to look now
Old Nov 24, 2008 | 03:28 PM
OLDSCHOOLQUAD's Avatar
Hey man, welcome to the place!!!
I had this happen to me as well. What I did was I took apart the handlebar control (where the start button is) and found that it was a simple solder fix. The wire had broken loose and had to be soldered back on. Once that was done, it started no problem. Got the solder iron and solder at dollar store. It sure was alot cheaper than getting it looked at. Good luck, with these quads bouncing around like they do, sometimes wires come loose or break.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Ashley S
Jul 31, 2015 09:46 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
