who to use for porting?
Old Feb 5, 2001 | 09:57 PM
Paintballer's Avatar
My lt250r just choked bad. The thrust bearing on the side of the rod on the piston end split and sent a chunk down into the crank case. Luckily, I got all the pieces out. Unluckily, the piston got the one piece I didn't. Apparently it sucked it up through the intake ports and wiped out the piston ring lands. So I am in need ov a bore/piston job. I figured now is a good time to get the porting done too. I have tried contacting Eric Gorr, but he oesn't answer the phone, and his voice mail is full. I have emailed, but no response their either. Anyone else have a suggestion for a company that can do it all and do a kickass job at a fair price?
I need, bore/hone/piston/rings/gaskets/thrust bearings/porting.
Any help is appreciated.
Old Feb 5, 2001 | 10:51 PM
chrisjack's Avatar
I have 3 letters for your my friend. F-T-Z they are the suzuki MASTERS. www.ftzracing.com Check it out. the prices may be a little pricy.. but they are welllll worth the money.
Old Feb 6, 2001 | 12:50 AM
250r89's Avatar
If you want the best check out www.macdizzy.com he's unbelievavle. And very fair
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
