2001 lt80
Old Dec 23, 2008 | 10:37 PM
stark767's Avatar
Default 2001 lt80
i just put a new starter in it it ran before i put it in i have no spark i check all the wires they are connect i have no power to the coil are u supposed to have power to the + to the coil
Old Dec 24, 2008 | 10:41 AM
LT80's Avatar
LT80 Expert
Default 2001 lt80
Welcome to the forums.
Yes, power to the coil, when the motor is turning anyways.
Did you check the spark plug cap? Connections under the hood?
Old Dec 24, 2008 | 01:33 PM
stark767's Avatar
Default 2001 lt80
ya i check every thing i have no power going to the coil
Old Dec 25, 2008 | 10:05 AM
LT80's Avatar
LT80 Expert
Default 2001 lt80
When you spin the motor, right?
If so, I'd pull the flywheel and sand/clean the stator. Sometimes that helps.
Old Dec 27, 2008 | 09:12 AM
stark767's Avatar
Default 2001 lt80
ya i did all that i need to test the coil primary and the coil lighting do u have to know the ohms spec on that
Old Dec 27, 2008 | 10:38 AM
LT80's Avatar
LT80 Expert
Default 2001 lt80
Sorry no. [img]i/expressions/face-icon-small-sad.gif[/img]
One was 86 or so but I forget.
Old Dec 27, 2008 | 11:14 AM
stark767's Avatar
Default 2001 lt80
ok thanks for all your help
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
QuadRiders
Oct 22, 2015 04:13 PM
35dodge
Sep 29, 2015 09:40 AM
merryman
Sep 19, 2015 03:15 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
