Suzuki Vinson Leak
Old Dec 29, 2008 | 09:38 AM
louisiana.brandon's Avatar
Default Suzuki Vinson Leak
I am definitely not a mechanic but have been keeping my fluids changed more than regularly. Well yesterday I was doing the oil/diff/bevel fluid change on all the 4 wheelers and noticed that the front diff (manual calls it the bevel) was leaking fluid from the right side (if you are looking at it from the front). Any ideas what this could be? Anyone ever have this problem before? I drained the existing fluid and it still had some in it (so it wasn't dry thank goodness). This may be beyond my abilities but I do not want to get bent over by a shop this soon after Christmas when money is tight...
Old Dec 30, 2008 | 12:49 AM
cherokee99's Avatar
ok, 1. did you fill the front diff with the proper amount of fluid? 2. if so, the seal/bearing is warn. if you are confident in your mechanical abilitys you can do it at home. but if not it is a job for a mechanic. there are seal and bearing kits avalibal on the net or threw a dealer
Old Dec 30, 2008 | 08:39 AM
After extensive research I also think it is a seal/bearing issue on that side. I did find the bearing/seal kit and also a detailed picture by picture "how to" on how to remove the front diff on the vinson. Just got to get the courage to do it!
Old Dec 30, 2008 | 10:57 PM
I need to move it from where it is to take it to where I can work on it. Is it ok to move it as long as I keep it out of 4wd?
Old Dec 31, 2008 | 12:57 AM
cherokee99's Avatar
i would not ride it out on the trails, but moveing it around wont hurt it
Scooter's Shop
Oct 9, 2015 02:09 PM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 08:03 AM
Sep 1, 2015 11:59 PM
