ozark torque problems
Old Jan 22, 2009 | 01:13 AM
d_odom1600's Avatar
Default ozark torque problems
i have a 04 suzuki ozark. we cleaned the carb several times, installed a new fuel **** assembly(on/off) and will crank right up and drive fine, BUT it is not fast as what it should be and you can hold the front brakes and FLOOR it and the tires do not move. i need help. thanks
Old Jan 22, 2009 | 11:28 AM
atvman29's Avatar
We have an 02 with tons of miles and our clutch is starting to go. Maybe this is your problem?
Old Jan 22, 2009 | 12:19 PM
cherokee99's Avatar
is there any clutch adjustment? are you using ATV engine oil...car oil can damage your clutch and meke it slip
Old Jan 22, 2009 | 08:06 PM
d_odom1600's Avatar
it drives fine through the gears it just takes forever to get to 5th gear. its slow and there is no power
Old Jan 23, 2009 | 04:20 PM
SuziOzark's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cherokee99
is there any clutch adjustment? are you using ATV engine oil...car oil can damage your clutch and meke it slip</end quote></div>
Seriously!? Uh-Oh.
Im thinking either clutch or possibly not enough engine compression anymore?
Old Jan 25, 2009 | 10:46 PM
GrnXnham's Avatar
Have you cleaned your air filter regularly? To prevent power loss, keeping the air filter clean is more important than changing your oil if you ride in dusty conditions.
If you are just losing power I'm thinking compression also not clutch.
Did the power loss happen gradually over many months or was it a sudden power loss? If it is more sudden, it might be a carburetor problem.
Old Jan 26, 2009 | 09:17 AM
abe65's Avatar
Sounds like the carb is messed up. This happened to me once after cleaning a carb it was the diaphram on the needle jet assembly. It was torn and not sliding up and down properly. With the air cleaner side of the carb of lift the sliding needle jet up while reving it and see if it revs better.
Old Jan 26, 2009 | 08:12 PM
Ol' QS230's Avatar
Make sure the back brakes arent dragging.
Old Jan 28, 2009 | 06:53 PM
SuziOzark's Avatar
You may also be running your engine too rich. Are the carb screws set to factory settings?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
traumajunkie
Jul 5, 2015 03:03 PM
