Eiger stalling out
Old Feb 2, 2009 | 11:31 AM
Dallas700's Avatar
Default Eiger stalling out
I bought a used 2006 Eiger this weekend that only had 62 miles on it and it has been setting for a while. The quad runs strong once it's warmed up but when you come to a stop and just feather the gas a vrey little bit it will die unless you blip the throttle. I pulled the bowl off the carb and cleaned it out with carb cleaner and pulled each jet out and spryed them out as well. With the quad in gear if you give it just a little bit of gas as if you wanted to go forward or backwards 2ft it seems like the tranny starts to load the motor and it will die. As long as I give it 1/4 throttle or more it will not die. What do you think?
Old Feb 5, 2009 | 07:25 PM
DEERHAWK's Avatar
How well does it idle after it warms up? It might need the pilot screw adjusted.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
