timimg chain replacement ?
Old Feb 11, 2009 | 07:26 PM
muddyweekends's Avatar
Default timimg chain replacement ?
ok i got a 83 lt 125 , the timing rails are wasted, and th4e chain as slack init .
do i have to pull the side cover off the motor to replace it or does the new chain have a master link init.? where i can roll it in.?
i never pulld the stator off be4 looks like i need a spaecil tool right ?
and how do you go about reseting the tensoir? do i leave the blot i little loose so the spring can go back and forth .or lock to down after i screw in on?
thanks
Old Feb 12, 2009 | 08:53 AM
bump of the day ?
someones got to know
Old Feb 12, 2009 | 11:06 AM
most of the cylinder wear is at the bottom .not the top?no lip at all.
going to get it checked out tomorrow im going ride my grizzly now
Old Feb 13, 2009 | 02:11 AM
Wrenchnalldatime's Avatar
First of all can you pick up the slack with new guides? There is no masterlink in the timing chain you'll have to split the case to do it, the stator can stay in the case. As for the tensioner you don't adjust it till you are putting it all back together. Once it's all in order you put a screwdriver into the tensioner turn it ccw insert the 2 bolts tighten them up and replace the bolt in the tensioner. Cylinder wear will be at the bottom, check the clearance in the middle of the stroke not at the top. Thats where you get a true reading.
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
