1996 King Quad 300
Old Feb 13, 2009 | 10:04 PM
joefig1's Avatar
Default 1996 King Quad 300
First time owner of a Quad, will be using it like the old timers (49ers) did
there mules. at times miles from nowhere and anybody.
have had it out a couple times trying everything out, changed all fluids
what else should I do or check
TIA Joe
Old Feb 14, 2009 | 08:32 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
If you want to use it like a mule, you've got the perfect quad.
KQ's are prone to having the brakes stick if stored after a wet or muddy ride. The brakes don't seal very well and the shoes will rust to the drums.
Lots of slow crawling can cause overheating, some have added a switch operated cooling fan.
If you hear a clicking noise in cadence with your speed and especially if you can chenge the noise by switching in and out of 4wd, check the rear U-joints.
For all quads, if you are miles and miles out and if you are traveling alone a few extras can get you back:
1. Get a winch. Any 4wd can get stuck but few stay stuck with a winch.
2. Tire slime. Do all four tires.
3. Extra fuel. While the KQ is fairly frugal on fuel usage, if you get into a lot of slow speed crawling in 4wd your range will go down in a hurry.
Jaybee
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
