1989 Lt 80 4 wheeler
Old Feb 17, 2009 | 02:30 PM
manleytoyz's Avatar
Default 1989 Lt 80 4 wheeler
1989 Lt 80 4 wheeler engine oil capacity I don't know how much oil to put in my sons bike.
Old Feb 18, 2009 | 11:42 AM
95wolv's Avatar
The LT80 is a 2 stroke, takes no engine oil, it does have a small amount of transmission oil that can be drained out and replaced, about 8ml or so, I beleive it is stamped by the fill bolt. Did you remove a small bolt on the side of the motor and have oil drain out? that is the only place on the motor that has oil in it besides the oil injection resivior and of course, the drain on the stock silencer, which will hold quite a bit of oil if you don't drain it once every few months or so. I hope this information was of help, I'm not trying to be a smart alec or anything, I used to own an LT80, just trying to help.
Old Feb 19, 2009 | 08:12 PM
Budds's Avatar
Your LT 80 is a 2 stroke however it is oil injected and should hold approx 2quarts of oil.
Old Feb 19, 2009 | 10:21 PM
Monkeyfish's Avatar
As said the LT80 has a transmission at the rear of the engine case. It holds 80ml of oil, in the manual it says 20w40 but any decent 10w40 motor oil will work fine. The filler bolt is located on top of the case above the front sprocket.
wrencher82
Sep 30, 2015 04:27 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
