LT230S Questions?
Old Feb 23, 2009 | 12:05 AM
Landscapeman's Avatar
Default LT230S Questions?
Ok, I have a 1988 230S Quadsport which I purchased around 7 years ago. When purchased I was told that it was bored .80 over. Also ported, polished and had a upgraded cam. It ran for about 2 yrs without a issue and then got hit with a stater problem. Well it sat for year, I rebuilt the carb, replaced: Handlebars, throttle, throttle cable, kill switch, spark plug, oil filter, and coil. When doing so I noticed that it seemed to have a valve clatter and did not want to idle. I was thinking that the valve springs were bad and need replacing. I spoke to a mechanic and was told that it need a full rebuild. I need some direction on where to go from here. Can I adjust the valves and be fine or do I need to replace them? Thanks for the advice.
Old Feb 23, 2009 | 08:06 AM
LT80's Avatar
LT80 Expert
I'd adjust and go from there.
A compression test may help.
Old Feb 23, 2009 | 10:03 AM
JustRandy's Avatar
If the engine doesn't smoke, I would just adjust the valves (whatever the recommend lash is by the cam manufacturer), go for a few rides and check the intake valve again. If the gap closed any, you'll need a new intake valve. Other than that, I don't see a reason to tear it apart.
You should also check the cam chain tension. A loose chain flopping around could be producing the noise you're hearing.
Old Feb 23, 2009 | 12:40 PM
Thanks for the reply's. I will check out the cam chain and the compression.
Old Feb 1, 2012 | 09:32 PM
CustomLt230S's Avatar
Default Spark Plugs
I am building a lt230s now from scratch i have three motors and strangly they all have different sparkplugs in there i am wondering because i am building this bike to sell i am doing a top end rebuild. SO MY QUESTION IS what is the OEM/aftermarket spark plug part number the one i took out of the motor im building is NGK R dr8es-l from what i have researched thats not the plug i should be using so i would appreciate an answer asap the topend rebuild is going to be stock bore NO BORING ALL STOCK MOTOR !!!! thanks guys !!!!
Old Feb 10, 2012 | 07:02 PM
firestorm10t's Avatar
If there is anyone looking for suzuki lt 230 answers ther is a web site called suzuki vault lt 230s this has all the specs, ignition timing, spark plug info, timing, ect. very useful. I am currently lookingto buy my second lt 230s. I rebuilt my first one and sold it. that site also has valve lash settings and everything.
Old Feb 11, 2012 | 10:01 AM
MIsuzukilt230s's Avatar
D7EA NGK
X22ES-U Nippon Denso
A6YC Champion
Gap .024 - .028
This information was found at the vault. The guy in charge is trailrider230s who is a member on these forums. There's a link to the vault in my signature below.
Old Feb 12, 2012 | 09:09 PM
Trailrider230s's Avatar
Originally Posted by MIsuzukilt230s
D7EA NGK
A6YC Champion
Gap .024 - .028
yeah i still lurk around the forums. anyone that needs help, just shoot me a pm, and i should be able to answer the same day. Been workin two jobs for a while now, so i haven't been on the forums much.
lonerider856
Oct 13, 2023 03:45 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
