overheated now oil in water Z400
Hello all, Im working on a friends 03 Z400 she ran a stick through the rad.and her son unknowingly kept runnin it overheated evidently.He said he shut it down when the temp lite came on but who knows,any how put a new E-bay radiator in it last nite and its gettin water into oil.My question is do these have a seal or something behind impeller of the pump that would allow water into crankcase if failed or is the head gasket the only means of water entry? thanks in advance J.
Before you pull the head/cams, check your valve lash. This has nothing to do with your oil problem, but proper valve lash helps ease starting and idling. My stepson's Z started running rough and was hard to start. I checked and adjusted the valve lash and she now purrs like a kitten!! You will need a valve shim kit from HotCamms (about 50-60 bucks on E-bay), but you might get lucky and be dead on.
Customer Service #1
05-15-2020 08:46 AM
jrooker6
04-23-2016 07:36 PM
