LT250 Compression
Old Apr 7, 2009 | 04:15 PM
muddogDave's Avatar
Default LT250 Compression
Does anybody know how many pounds of compression a 250 should have?
Old Apr 7, 2009 | 06:25 PM
onebigzj's Avatar
I would guess around 125psi for a stock motor.
Old Apr 7, 2009 | 07:05 PM
NewportHillClimber's Avatar
lt250r or lt250s?? 125 for r and minimum of 150 (wear limit) for s
Old Apr 7, 2009 | 07:09 PM
onebigzj's Avatar
good call never thought about the lt250s.
Old Apr 7, 2009 | 09:22 PM
muddogDave's Avatar
It is a LT-F250
Old Apr 7, 2009 | 09:27 PM
onebigzj's Avatar
4 stroker 150psi
Old Apr 8, 2009 | 08:40 PM
150 is minimum. you really want closer to 200 but not over 250
Old Apr 8, 2009 | 08:49 PM
onebigzj's Avatar
does this machene have a decompression lever that will make the comp test hard to do??
Old Apr 11, 2009 | 08:14 AM
muddogDave's Avatar
It has a decompression lever. Does this engage when using the starter?
Old Apr 11, 2009 | 11:41 AM
onebigzj's Avatar
ya it opens the exhust valve when starting. if there is a way to bypass it from opening when starting that is what you are going to have to do. some times its a cable or a switch on the head by the valve that pushes the valve open. disconnect and hold the throttle wide open and hit the starter.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
